SDS100/SDS200: SDS100 DMR System will only decode private calls.
Ubbe
Stockholm, Sweden
The log show that you are only able to receive 164.525 and 164.700 and not the other channels, although they sometimes manage to break squelch but there's nothing to receive. Also the ones you can receive seems to be very weak or have interference issues as you have some bit errors to deal with.
TG's are taken place on LCN2 and LCN4 at different slots but there's no channel spacing in the scanner to use to match any of the frequencies scanned to LCN2 and LCN4 in a bandplan. It must be channels missing between 164.525 164.700 and you could try and search between those two frequencies. But if the signal are not strong enough, or if you have interference, it might be difficult to do. Maybe some different filter setting and IFX can be tested to see if that improves reception quality.
/Ubbe
