Found It ( Map to find your Radius )
dallascowboys
Dothan Alabama
Was doing some research and found this site that is Norton safe, all you have to do is go to www.freemaptools.com once there scroll down to where you can put in the radius that you want, go back up to the map find were you live and click on your location, should show you what you can receive because the map will draw a circle for you. Than you just write down what you see on the map that you should be able to receive. Hope this helps someone trying to find location base scanning and radius.
