FPS and DEA
Listening to DEA Dallas Center right now, Analog and in the clear. 418.6250 PL: 156.7 running 28's with Military Phonetics.
texasemt13
CenTex DBA
Hunter, TX
I've been hearing a bunch of FPS traffic this morning. It seems that 3 different cities are having "demonstrations" at federal buildings. I have confirmed that while in San Antonio I can hear the Austin units as well (Paul and George). But, I can't figure out what the 3rd city I'm hearing is. For a look at what cities it could potentially be see here.
If someone is keeping track of which units they are hearing please let me know through pm so I can verify what other city I am hearing (cross referencing addresses has only helped verify Austin and San Antonio).
410.8000MHz 201 NAC
texasemt13
CenTex DBA
Hunter, TX
Heads up! On 410.8000 I've also heard NAC 715, and from what I can find this NAC has not been heard anywhere else. The units I've heard on this have been out of Austin, Texas and with the signal strength I'm getting each time I believe it is only coming from there. I have not confirmed its use in any other city yet, but be on the lookout, I've left my PSR500 in NAC seach to find anymore. These units were in contact with Denver Megacenter so this could possibly be a region wide NAC.
ericcarlson
Houston, Texas
This dual-NAC thing is interesting. I got NAC 798 on 410.8 in Houston a little while ago with unit 716 talking to Denver. I've always seen NAC 201 in the past in Houston. The 7xx NACs appear to be regional with the 201 common across Texas from what I see in the database. Keep your eyes open and report what you find.
davidbond21
New Braunfels, TX
That's exactly what it is. All the major cities have for the most part their own 7xx NACs, and then the 201 NAC is for statewide Ch 1 access, and Ch 2(413.95 MHz) uses 293 NAC statewide as well. I have a complete list but it's not where I can get to it at the moment.
texasemt13
CenTex DBA
Hunter, TX
In San Antonio they have used channels 3 & 4 in simplex and repeated modes to communicate with ground units.
simplec6
I have a question about DEA in the DFW area.
I pick up DEA Ch.1:
418.62500 DEA Ch 1A DEA Dallas Center (Dallas Primary) FM Federal
418.62500 DEA Ch 1D DEA Digital Repeater P25 Federal
Database link: http://www.radioreference.com/apps/db/?inputs=1&aid=86#cats
And some of the other channels every once in a while as well, but all I hear is loud static that goes on and off at a frequency of about once a second. Very loud static and silence back to back for 3-10 seconds at a time.
Is this encryption or is it not programmed correctly in my 396t? I know I can't decode the NAC code, but I have it set twice, once as analog only and search mode, and once as digital only (both in conventional).
Am I doing something wrong? I've monitored DEA for about a month now and nothing but static so far?
redhelmet13
4 nm se KNFW
If they are transmitting P25 encrypted audio, it sounds what best could be described as R2D2 drank waaaay too much. Just a bunch of bleeps and churps and such...
If analog encryption, you would only hear "static".
texasemt13
CenTex DBA
Hunter, TX
It could be encryption, though one thought comes to mind. I'm not a Uniden guy, mostly own GREs, but in the last generation of digital "bank" scanners (as opposed to "list" I suppose), the order in which you programmed the frequencies mattered. Follow me for a second. If you have it (418.625) programmed twice, and as the scanner rolls along, it encounters the analog one first, and receives traffic, it will make a horrible buzzing noise, trying to decode the digital signal. Since it encountered the analog one first, and locks up on that, it never reaches the one you have stored as digital.
While the static is happening, do you ever manually pause/stop/wait on the digitally stored frequency to listen? I would.
It could very well be encryption though. I'd just like to rule the programming setup out first.
If it was stored in the opposite way (or scanning from the opposite direction), digital first, then the analog one, this would not be the factor, and it could be ruled out. But, if the analog one is encountered first, then the digital, it could be the problem.
simplec6
Oh, I see. Great idea, I will switch over to the digital if it picks up on the analog first. I haven't paid close enough attention to tell if it is stopping on the digital or analog.
Last night, I could hear the chopper talking, but when the ground units started talking it would be that loud static sound that goes on and off at a frequency of about once a second.
I thought more people regularly listened to DEA so I was hoping I just had the frequencies wrong or something. Hopefully I can get it figured out tonight.
Since I have the 396t, it can't decode the NAC, so I hope that's not what's causing my problems!
Thanks emt
hiegtx
Dallas, TX
Thanks emt
On the 396T, if you program a conventional frequency with the tone/code field set to "search" (in other words, you're trying to determine if a PL/CTCSS tone, or DCS code is being used), the scanner will ignore digital transmissions. It would pick up analog signals only, and would display the tone, or DCS code (if any) found on the signal.
If you, instead, enter "none" in that field, the scanner will receive both analog and digital signals. It would not display any tone or DCS code information, but a small "P25" would appear when a digital signal was being received.
The same behavior applies for Close Call or Custom Search settings. Telling the scanner to search for a tone or code will cause it to ignore digital signals during a search.
Ensnared
Waco, Texas
I recorded analog DEA traffic last March in the Dallas area around IH30 and the west end area on a digital recorder. Wow, what a catch.
I have the recording of such, but cannot post it because I don't currently have a open source method of transferring the MP3 into a URL. Most of the ones I've tried have eventually asked for money. One day, soon, I am going to buy such a program & get back up to that area to scan the DEA, my favorite agency.
I am curious about the open discussion of monitoring such agencies. In Waco, I am purposefully keeping mum about the surveillance traffic I've been hearing as of late on TxWarn and analog channels. I don't know how "informed" local LE are about RR. I don't want to encourage them to flip that switch.
Real easy well to tell what you're hearing: if the "static" has a brief high-pitched beep at the end of it you're hearing analog encryption. If it doesn't, it's P25 or something else. Use these sound samples for reference: P25 - Analog DES Encryption
simplec6
Wirelessly posted (Opera/9.80 (Android; Opera Mini/5.1.22460/22.453; U; en) Presto/2.5.25 Version/10.54)
Ok thanks for the guidance guys.
I think everything is programmed right because on system is directly imported from RR, and the other that scans the exact same feds is from hiegtx's file he shared with me, which saved me tons of time.
Something might be wrong with my 396t though is no one else has noticed this weird problem on the Dea freqs.
At least a few times a night/day, sometimes over 50 times in a day,
it will stop on the digital channel and I will hear this noise. it is a normal static sound that lasts about half a second, and then half a second of silence, which repeats for the duration of the transmission. I experience this behavior on both the digital channels and the analog channels as well. it is very weird. I have heard them every once in a while though and it sounds nice and clear on the same exact channels and systems that do this weird noise.
I figured if this is normal then one of you guys would certainly know what I'm referring to.
And of course no Intel or surveillance should be discussed here, its just fun to listen to.
simplec6
I pick up DEA Ch.1:
Database link: Federal Agency Frequencies Scanner Frequencies and Radio Frequency Reference
Guys! I finally ran across the dang annoying noise i was talking about in this post!!!!
It is, indeed, "OTAR" (Over-The-Air-Rekey). And it's loud and obnoxious! I wish I could make it stop. I've just locked out those DEA freq. now because it was so annoying to hear that all the time! I don't know how you guys put up with that noise, but I sure can't.
ecps92
Taxachusetts
Is DEA Dallas [what Freq?] Analog aka 156.7 Hz or P25 $156 ??? :confused:
