Freescan scanner optimizer
According to the optimizer, it has found some invalid talk groups for the OC Transpo system. But i have ignore it. I wonder why it would show that?
I some what dissagee with it as I think they need operation channels is the optimizer 100% right ??
It someone else can confirm
1507
1523
1562
1535
1503
1595
1510
1561
I would like to know if these are still active or not?
According to the computer but I would like to know for sure if they are ?
So is it okay for me to delete the invalid ones ?
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Those look like they have five digits. I can't tell for sure because the picture is blurry. Although the last character may be a question mark. Can't tell for sure. Get rid of them. You must have programmed them twice.
Those look like they have five digits. I can't tell for sure because the picture is blurry. Get rid of them.
I can’t help about the camera, but i will remove the invalid ones.
Try this. That picture is what is left over after I got rid of invalids
  • OC transpo talkgroups.zip
Enjoi19
Ontario, Canada
Freescan has no way of determining if a talkgroup is actively used.
Put them in and see if they ever become active. Some may be seldom used but not necessarily gone from the system.
RadioReference doesn't generally remove talkgroups from the database unless they can receive a hard confirmation they've been removed from the system and deprecated. It can be helpful for those discovering new talkgroups to line up the numbers with existing / previously used ones.
thecanadiangod
Ottawa
1507
1523
1562
1535
1503
1595
1510
1561
These are active yes, but not often. They are used from time to time.
wtp
Port Charlotte FL
Ronaldski
MI DB Admin
Bay City MI
System, Ottawa Trunking System, Ottawa, Ontario
I just used Freescan and copied over the OC Trans system. IMHO ,since I don't see the premium subscriber on your name you must have copied it and pasted it over incorrectly somehow or used EZGrab and set the columns/Talkgroups incorrectly.
Anyway here is OC Trans I setup for you, I removed the DE's - encrypted's as well. You'll have to uncompress/unzip the attached to use it in freescan.
No need to buy other software, re-learn that and start all over again.
  • OC.zip
I just used freescan and copied over the OC Trans system. IMHO since I don't see the premium subscriber on your name you must have copied it and copied it over incorrectly somehow or used EZGrab and set the columns/Talkgroups incorrectly?
Anyway here is OC Trans I setup for you I removed the DE's - encrypted's as well. You'll have to uncompress/unzip the attached to use it in freescan.
Ok Thank you very much !! :) I will do that right away I have another question about it but it doesn’t have to to with OC transpo it Il DM you !
What you referring too as program file ?
If you mean what system I scan I can upload and send it over
The system I have is NXDN conventional and P25. Those are all of my systems
