FreeScan vs ProScan
rufust
Upstate NY
Just recieved my shiny new BCD996P2 and had my first what have I gotten myself into moment.I am a raw novice and programing is going to take a little study.What is the best software for this scanner and a Newbie Operator ?
Thanks in advance
troymail
Silent Key
FreeScan being "free" seems like a good place to start before handing over your dollars... You can always hand over your money tomorrow....
I use FreeScan to program an old 396T and other radios for other folks... never really had any problems with the software itself - more, it's just limitations of this old(er) radio (12 years old now?).
From reading the threads, one thing to consider (as I understand it) is that FreeScan doesn't handle or known anything about DMR should you have or plan to get that upgrade. But again - that doesn't mean you should want to run out and spend more of your money unless/until you decide that's really what you want to do.
Regardless of which software you opt to go with (you will want one or another), I strongly recommend taking the time to learn about manually programming the radio for a variety of reasons....
NYRHKY94
Brunswick County, NC
In addition to the good advice from troymail above, Proscan offers a FREE fully functional 30-day trial of their software. Given what Proscan has to offer (best all-in-one programming/remote control software on the market IMO), there is absolutely no downside to giving it a test run. You can also use the web import feature to program your scanner automatically using your Radio Reference ID & Password as well. Good luck!
Whiskey3JMC
Another Pesky Scanist
Simulcastylvania, TE
I give Proscan two thumbs up. I use it to remotely control 4 Uniden radios on the same computer without a hiccup. Web server remote management feature certainly is nice too. As the user above me mentioned, download the free trial & see if it is right for you
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
<snip>
To get you started, see this article from our wiki (links are blue)...
Program your DMA Scanner - The RadioReference Wiki
Read the stuff in the Nuts and Bolts section first; then go down to the bottom to get the Easier to Read manuals. I'd download it (free). or order a printed copy from Scanner Master.
Mike
troymail
Silent Key
just remember free is not always better.
Just depends on what you need it to do... I've tried sme of the "paid" software and continue to succesfully use the manufacturer supplied software without any major impacts. In the case of the "older" radios that have recently been given new life and don't provide software, in general they are just going to be a bit more difficult to program (you get what you pay for).
Having said that - I'm sure a piece of software that you pay for should be better ... the question is - just it justify the cost. Ultimately, it's an individual decision...
hiegtx
Mentor
Dallas, TX
FreeSCAN works well in most cases. However, if you add the DMR upgrade at some point, you will need to use ProScan or ARC-XT. FreeSCAN was not updated for DMR, and if you try to "read" a DMR system into it from the scanner, you'll get an unusable mess. Because of this, I am using ProScan, which covers a larger number of scanners, including some older units in my collection.
mule1075
Washington Pennsylvania
This:
http://forums.radioreference.com/uniden-tech-support/360219-no-trunking-receive.html#post2831253
is why I said (always say) this:
100% agree on learning to program by hand.It might be a pain in the butt but well worth the effort.
Sent from my SM-S907VL using Tapatalk
