Frequencies & iScan software / RS Pro-668?
JRUNCK
When scanning for frequencies I stored 856.087500 after listening to it into my default playlist 01 on my Pro-668. My playlist almost always picks it up when I'm scanning my playlist 01 listed as "Stored Search" so I know it's the one I stored manually on the scanner. When I researched the frequency I found it listed under "Seattle-King County Public Safety" under the "EPSCA Simulcast". I looked in the iScan software on my computer and see the same information listed under the "Trunked Radio Systems" tab. I've used the "Update Channels" option under the "Library Import" tab and from what I understand this should sync the information from iScan to my scanner.
I have a few questions regarding this . . .
I understand why my scanner picks up the 856.087500 frequency as a stored search but don't understand why it doesn't seem to pick it up with the information I synced from iScan to my 668? If my scanner does have the same frequency synced from the "EPSCA Simulcast" how can i verify it on my scanner?
How do I confirm that all data is being synced from iScan to my scanner? (settings, locations, advanced features ect.) I've tried changing the general setting for "Key Beep" to off using the iScan software and then tested it on my scanner but the beep was still on. So this is another area I'm not sure how to sync the data from software to scanner and haven't found an answer in the help menu.
