Frequency encryption
jrib65
Is Marin County police and Fire frequencies encrypted?
Whiskey3JMC
Quiet numbskulls I'm broadcasting!
Simulcastylvania, TE
Welcome to the forums. Here's a tip for you: Hover your mouse cursor over the Mode column heading on any given database table & you'll see the following...
jrib65
I bought the BCD996P2 scanner. I had it programmed through the Uniden programming service on the flyer that came with the scanner. They programmed all the stuff. Upgrades and everything. It scans and say there is nothing to scan in Marin.
I think they did a good job as it shows the Novato police department frequencies, but my scanner is dead silent on those frequencies. I looked up counties with encrypted frequencies and San Francisco is one of them. I figured Marin county, Sonoma county followed SF's lead.
I'm not a radio guy. I know just enough to ask for help. I looked up Marin in the Radio reference.com and it shows no frequencies pertaining to the sheriff, police, fire, etc.
I'd like to believe I'm doing something wrong. I just wanted to hear what all the fuss is about when all the sirens go off in town.
I appreciate all the help and the fast response. It's not performing the way I expected. 20 years ago I could turn on my Radio Shack scanner and get all the chatter. Now, not so much.
John
ScanRafael
San Rafael, California
I recommend that you return your BCD996P2 and spend a bit more for a BCD436HP or BCD536HP. Learn to program it yourself using sentinel software using this link. I was in special ed and even I figured it out. Changed my life.
Brales60
Punta Gorda, Fl
Antenna? I couldn't get dodo inside my house with factory antenna. I put up a external Omni X about 20 feet up, and my 996P2 was better, but not great due to simulcast. I bit the bullet and bought a SDS200, and life is good. Huge difference. I've read the complaints about the SDSXX with analog, but I've had no issues. Maybe it's the antenna.
ScanRafael
That is a great question. Are you getting signal bars and receiving data from the control channel?
Brales60
Punta Gorda, Fl
If you're referring to signals on the 996, yes I was getting full bars. Problem was the distortion due to the simulcast. The SDS200 fixed that. My house is completely foil wrapped insulation including the attic, and that's why I just got zero reception inside till I put up the external antenna.
ScanRafael
My question was directed to @jrib65, but thank you for answering.
jrib65
I am going to return the BCD996P2 and try the SDS200. It's a little more expensive. I want to know what all the fuss is about when the cops and sirens and firetrucks start making a racket in town.
I live a tad on the outside of Novato next to open space, so when the cops or a helicopter comes into our neighborhood, it's a rare occasion and I want to know what is going on.
Society has a one fits all perception on who is smart and not. Intelligence is subjective. Us quiet people are considered "special". We have integrity and a great sense of perception that can't be easily expressed, easily. My teachers thought I couldn't read until the 5th grade.
JAR
ScanRafael
JAR
I think your money would be better spent on a BCD436HP or BCD536HP. The SDS series don't receive analog (i.e. CHP) as well. I own a 2 BCD436HP's and they work great for me all over Marin County.
jrib65
You can hear what all the stuff that's going on in Marin? I get nothing. Your probably right on me getting the BCD436HP.
I bought all this stuff from Amazon so it's easy to return and replace. Did the BCD436HP automatically install the frequencies or did you have to do some searching? Where are you getting the frequencies from? I have this list, attached, to work from.
I'm learning.
Thank you for your help.
  • Marin Emergency Radio Authority (MERA) Trunking System, Various, California.pdf
ScanRafael
I'm learning.
I initially would enter my zip code and scan the full database until I discovered how to make favorites lists with the sentinel software.
officer_415
SF Bay Area
MERA uses C4FM modulation, there shouldn't be any issues with simulcast distortion and his BCD996P2 scanner should work fine. @jrib65, PM me and I can try to troubleshoot it with you.
jrib65
I got the SDS200. Very easy to set up. I'm getting chatter I could not get with the BCD996P2. I'm getting a lot more out of the SDS200.
It's a quiet day here in Novato and that's a good thing.
Officer_415 I don't know what "PM" means. : )
officer_415
SF Bay Area
Private message, but if your SDS200 is working then disregard. I'm sure it was just an incorrect setting on the BCD996P2; no reason that scanner shouldn't receive MERA.
jrib65
I ended up buying the BCD436HP and I like it. I used the Sentinel programming software. Fairly easy.
It's pretty quiet in Marin. Or am I missing something?
