Yaesu: FT-70D driver installation
braluca
Hello,
I am using Windows 10.
I installed FT-70D Programmer ADMS-10 on PC
I connect FT-70D to PC, radio is in ADMS mode,
then I try to install driver sw
On instruction manual of ADMS-10 at point 5 I read: Under "other devices" right click [Unknown devices]... (referring to Device Manager)
I have not other devices in the list
Could you please help?
ko6jw_2
Santa Ynez, CA
I had trouble with the ADMS-10 software. I would suggest investing in RT Systems software and cable. They have worked well and the documentation is better.
Hit_Factor
Saint Joseph, MI
No driver required.
The FT3DR ships with a USB cable dor firmware updates only. A special cable is required for ADMS software.
Get the right cable.
Your problems are just beginning if use ADMS.
Check your manual, I bet you need the CT-27 cloning cable.
braluca
At the end I was able to install the driver, under "other devices" was not the right place in my case, it wasin another one.
And now when I transfer data from Radio to PC: Timeout error
WRA849
Are you pushing the band button on the radio as soon as you initiate the transfer? Need to do it quickly.
k6cpo
San Diego, CA
No driver required.
The CT-27 cloning cable is for cloning from another FT-70. It doesn't connect to a computer.
As others have said, get the RT Systems cable and software. It's worth the price to not have to hassle with programming.
N4DJC
Upstate
The FT-70DR uses the USB cable shipped with the radio for programming and firmware upgrades.
