R30 Ft8 decode with PC
Gloux
Hello, I have owned an icom ic-R30 for 1 year but haven't had time to get it to work properly.
Today, I would like to decode FT8 on the amateur radio bands but I cannot transfer the sound from the receiver to the PC.
Someone can help me ? DO I need an audio cable or is the USB cable sufficient?
Thx for help
Stephane
kinglou0
Yes, you need an audio cable to carry the audio to your computer.
USB is only used for charging, writing to the unit/SD card, and controlling the receiver with specific software.
I imagine you could also get audio to your computer via Bluetooth but why complicate things?
Gloux
Thanks for your help. i tried using bluetooth but i can't connect the devices, always on error . I tried to connect the audio directly with a cable but I will have to do an isolation because it generates qrm.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
From what little I understand of this, you will also need to calibrate your PC's clock to an exact standard for FT8 decoding to work. I'm sure someone will jump in on this....Mike
Gloux
Yes, time is very important to decode s FT8, JS8, etc ... messages
STe
jazzboypro
Laval
Since I own an R30 here is what works for me.
First, I'm sitting outside with my laptop and I'm using the stock antenna on the R30.
I started by installing the R30 driver that can be downloaded here Driver
You need two cables to make this work. An audio cable between the audio out connector on the R30 and the audio connector on the laptop/computer
The second cable is between the USB connector on the R30 and the USB connector on the laptop. No special USB cable needed.
You then need to configure the USB settings on the R30. There are to settings to configure (don't know why the pictures are sideways)
Then you need to configure WSJTX
Here are the results on 20 meter
Hope it helps
