BCD325P2/BCD996P2: Function Knob Unresponsive
RTmed519
The function knob on the BCD996P2 is completely unresponsive. I can push it and use it as a function button (to turn on quick keys), however when I try to go through menus, switch between frequencies while on “hold” mode, etc, it doesn’t respond to the turn dial.
RTmed519
Since making this post about 15 minutes ago, it’s started working again after trying everything. No idea why it started working again. It may be because the scanner was too cold?
Ubbe
Stockholm, Sweden
If it happens again, follow the cable that goes from the controller circuit board to the main board and lift and re-seat that connector. For some reason Unidens scanners sometimes need their connectors excersised to make good contact again.
/Ubbe
