G1 AAA Batteries
LubeckTech
Parkersburg, WV
What batteries are those of you using G1 pagers finding work best?
How are you dealing with totally dead batteries which the charger will refuse to charge??
I tickle them with a charged battery to get a small voltage into them at which point they will charge but would like to find a charger that could wake them up.
911jeremy
Charleston, wv
Unication has spent a lot of money testing batteries for their pagers. they found that the Tenergy Premium 100mAh Battery is the longest lasting best battery for their G1. Being a Unication Dealer this is the battery Unication urges us to use and sell.
kruser
Well Known Member
W St Louis Cnty, MO
I use the White Eneloops.
The old saying that you learn something every day must be true! I didn't even know they made the popular white Eneloop battery in the AAA size!
Thanks for sharing that link.
LubeckTech
Parkersburg, WV
The Tenergy is what we have been selling but I am hoping to find something better as they seem to self discharge fairly quickly and then the Unication charger does not want to charge them. The problem is the charger won't provide enough current to charge a totally dead battery. I currently hook one in parallel witha charged battery of the same voltage for a couple of seconds which will impart enough charge to the dead battery to satisfy the charger. I will probably get some eneloops for evaluation. They are well spoken of in many reports and not that much more expensive.
w2lie
New York DB Admin
Long Island, NY
I'll normally throw a pager with those super dead batteries in the programmer for about 30 minutes. That seems to be enough to throw just enough voltage in them so the SU Charger can charge the batteries.
I've talked to Unication repair and they don't think this is a problem. They've asked me to send back pagers, chargers, and batteries with this problem but it is easy enough to duplicate. I'm glad I'm not the only one seeing this problem.
LubeckTech
Parkersburg, WV
I called Unication about the problem and they are aware of the situation. I was told there is no plan to correct the problem of the chargers not wanting to charge totally dead batteries.
Their solution was for us to use an inexpensive "dumb" battery charger to get totally dead batteries up to a level the charger would use them.
Currently my solution is to use a 2x AAA battery holder which has been wired to connect both slots then put in 1 fully charged & 1 dead battery and immediately remove them. The dead battery will then charge.
