G4 amp charger problem
firebell9137
Hi. When I put my G4 into the amp charger it says out of range on the G4. Then i take it off and says in range. Any reason for this?
jtwalker
BEE00.1E8
Do you have an antenna connected to amplified charger base?
jtwalker
BEE00.1E8
First thing I would do is clean the contacts on pager and on base.
Brand new amp charger since 2 days ago. And just cleaned the G4 contacts and still does it
What is near it? Try moving it, I had mine near a computer speaker and it was constantly doing it moved it 6 inches away and it stopped. In your case may not be a speaker, but something else causing interference.
firebell9137
Could a light be an issue? It's an led light bulb. In a lamp shaped like usual bulbs.
firebell9137
Works fine for my G3 though
K9KLC
Southwest, IL
I'd still check the contacts on the charger. These things sit a while sometimes and could develop dirt or corrosion. Never hurts to check.
Firebuff66
CT
I had the same thing happen to mine with a G5. Sent it back twice and they sent me new ones twice..None of the 3 worked with the external antenna. In the end tried 3 different G5s and 3 brand new amp chargers and none would work with the external antenna.
Unication didn't really care so I moved on
ryolsen8
BEE07
I have the same issue with my G5's... Nothing is near it, and I've moved it around to different places. I gave up using it for the speaker, and just use it as a charger with the G5 off.
K9KLC
Southwest, IL
Guess I'm lucky then. 2) G5s and 2) amplified chargers and they both seem to be working better on some things on the charger than not in the charger.
blackbelter
I would suggest to contact your dealer and ask for an amp charger replacement. It might be the amp chargers antenna connector.
ryolsen8
BEE07
My amp charger is well past its warranty date unfortunately.
blackbelter
May I suggest to remove the amp chargers antenna while the G5 is inserted and determine if the OR is still there.
