G4 and G5 programming
elrod
R'ville,IL.
Probably a stupid question but here goes.
I have a G4 and G5 both are phase 2.
Can I load the same profile into both units.
Instead of creating a profile for example for the G4, and loading it in, can I then load the same profile into the G5 instead of having to create a duplicate whole new profile.
Any info would be helpful.
Chuck
Illinois
Chuck
The only problem with that is the G4 and G5 both use two different model numbers and if one VHF and the other is UHF than thats a issue. What you can do is under the tab Create new profile there is a option (Convert to new model) Which just basically copies your current profile but lets you change the model number.
