To anyone looking to acquire commercial radio programming software:
Can someone tell me exactly how to create a file with the 500+ unique radio ID's with alpha tags? Comma delimited is what I'm reading the file needs to be.
Open a spreadsheet and put "Call Alias" in the first column at the top, and "P25T SUID" in the next one (without quotes). PPS won't import without these. Add in your list. Save it as a .csv. There is a character limit for aliases of 14 - it'll reject those lines over that and tell you which ones were affected during the import on the new PPS version.
On the current PPS, tab E2, pick your system and put it under "Individual Call List" by clicking it and then the import button.
If you find yourself needing more than the 999 limit, you can either duplicate your existing system, or create a fictitious one to stash the rest. I found this out by accident, and it turns out to be a neat feature. Need more than 999 UID's??? Try this!
I took a look at the .csv and noticed right away that the data is entered into the wrong columns. No biggie, I switched everything around, and corrected a spelling error. Give this a try.
Yep you’re correct. I changed that and I’m good to go now. Oh, duplicate names will work without issue. was actually typing a post right this minute to update you.
