G4 problems
shfd7
Pike County, Mississippi
I have had a G4 now for about 3 years. Never been really wet, and only cleaned it with q-tips. About 3 days ago, it started to cut off and on. it will come on and go to the
scanning screen then cut off after a few seconds. It will even display the unication start up screen when its cut off. Computer won't even recognize it. I bought it straight from Unication and not a dealer. I did remove the battery to try to reset it. Nothing works. Am i looking at getting another pager or do yall think unication would be able to fix it?
picscan
CA
Have you tried cleaning the battery contacts, does it work off usb power? Maybe the cable is bad?
David628
Colorado
Not sure about the powering off and on issue? Maybe try to leave the battery out all night and see what happens, idk? One time before mine stayed locked on the Unication boot up screen. At the same time experienced the part where the computer won't recognize it also. What I did was to try another cabe. In my case a Samsung Galaxy cable worked. I was able to get it connected and downloaded the saved file I had which fixed both issues.
RBMTS
I agree with K6LEH. After 3 years it is most likely the battery.
N6ML
My first thought is dead battery too. Mine is just coming up on two years, and still holds enough charge for about 12 hours of operating, but I know that it's days are numbered.
IAmSixNine
Dallas, TX
When it does work what is the battery level at? If your computer wont recognize it maybe its not charging properly. How do you charge it? By using cable and plugging it into a computer? or a usb hub? or a usb wall charger? drop in desktop charger?
Is your battery swollen?
tvengr
Well Known Member
Baltimore County, MD
Try doing the 3 button reset. Hold the 2 buttons on the upper left side and the button on the channel knob all at the same time. If successful, it will come up to the Unication screen with dots changing color from left to right. It is not easy to do.
