G4 Programming Successful?
tweiss3
Is it time for Coffee?
Ohio
I just picked up a G4, and programmed it last night to test today. I really liked it, but as usual, had some tweaks I wanted to make. Not a big deal. I make the changes, hit program, get a "Programming Successful" message, shut it off, unplug the cable, then at power on I don't see the changes (I added to zone 1 slot 8 that was previously blank).
Firmware is 2.02 & PPS 4.0.41. I then figured could have been a glitch, and factory reset the pager. Now it's stuck at factory settings and won't take programming, but shows "Programming Successful" every time. Computer is Windows 11.
What am I missing?
lebrunmn
Retired... Get off my lawn!
Hampshire County, WV
Just a guess, but make certain you’re on the correct position/zone… oftentimes, I’ve programmed changes to the incorrect knob position. I’d check all 8 positions to see if your programming isn’t in another position.
Good luck!
tweiss3
Ohio
Good luck!
Yep, I checked that as well. I now can't even get anything programmed to it. I may have to reach out to Unication tomorrow.
tweiss3
Ohio
Or it programmed just fine on my home computer. I don't get it.
