G5 Boot Loop on NYCICN P25TRS
rjbegin2
Anyone else have a G5 go into Boot Loop after a minute or two of monitoring a system? I’ve had my pager for about 5 years now without issues. I monitor Orange and Rockland County, NY, MTA MRRS, Metro-25, NJICS, and PANYNJ 7/800 Trunk systems without any issues. I added NYCICN 800 Simulcast and the pager will receive Site 60 and I will receive audio if a talkgroup is live, but then the pager will restart after 1-3 minutes. I’ve pulled the battery for 15 min, removed all frequencies except the 4 control channels. FW. 1.31
KevinC
Encryption
I'm everywhere Focker!
What 2 bands is your G5?
KevinC
Encryption
7/800 & VHF. I only have the 800 mhz simulcast programmed, not the UHF Sites.
Is you FW current? This issue presented itself on a mixed VHF/7/800 system several years ago and I believe they fixed it. You didn't have to have the VHF sites programmed in, it was caused by a G5 without VHF seeing the VHF sites in the CC info. I would expect the same thing to happen for other bands as well. This also affected the G4 as it's single band.
Echo4Thirty
Colorado Springs, CO
Its not Unication's fault! Its Motorola's, even when its a Harris system causing it to reboot!! /s
rjbegin2
You should upgrade to version 2.02
Are these Harris systems? I’ve had to open tickets for a few of my customers who had their pagers rebooting monitoring Harris P25 systems.
Phil, that fixed it! Thanks. I was hesitant to upgrade when it first came out Incase there were bugs. The whole unit seems to run better, menu screens faster, and the Harris boot loop totally done.
w2lie
New York DB Admin
Long Island, NY
Glad it worked for you. Now you'll have to relearn PPS but at least your pager isn't rebooting.
