We have a customer with a G5 pager in an amplified charger that is having a very strange issue. With the pager in my hand, it will lock on to the nearest site in the next county....they work mutual aid with them. The county is using 800 MHz P25 paging. . So the pager will be locked on the site's control channel, and then I can put it in the charger using the supplied whip antenna and it will remain locked on the CC, but will occasionally go out of range, which is a problem as they want to use it for station alerting. So we installed an antenna on top of the FD, using an automotive 800 antenna on an NMOKUD cable running into the building and to the pager with a short extension added as the 17' isn't quite long enough. Here is the problem. If I connect the outdoor antenna directly to the charger, give the pager a few seconds to scan for towers and it will go out of range and stay out of range. If I disconnect the antenna from the charger and plug it directly into the top of the pager using an SMA to BNC adapter, the pager comes in range and never leaves. Put it back in the charger and put the antenna on the back, Out of range. Put the pager's antenna back on and remove it from the charger, in range....though RSSI is higher. I've checked the cables, I've taken the pager and charger on the roof of the building with a new antenna, cable, etc. and it still goes out of range but only when it's in the charger. We've scanned for any interference and found nothing close. I'm working with Unication, getting logs, updating firmware, etc. and I wanted to see if anyone here could help me out with any suggestions. The site is only 8 miles away, and just for kicks, I put it in my truck and in the charger with a mag mount outside, it was picking up the CC from another site 22 miles away. The site I'm trying to hit, at last PM, produces more power out of the combiners than the one I tested at 22 miles. So I'm at a loss. I was thinking interference, but it only happens in the charger. Out of the charger, the pager stays in range. We've tried 3 pagers, 3 chargers, two antennas, two cables, replaced the connectors. Has anyone ever seen such a thing before?
