G5 no menus option for sounds and vibrating
thedanderzone
Wisconsin
If you plan to do other things with it (like monitoring a P25 trunked system) there are other videos that are out there about importing from radioreference. It’s really a pretty simple process when it comes to that, but I find the difficult process is understanding the layout for QCII paging that Unication uses. Once you get it down it isn’t too bad, but a definite learning curve.
thegmaniac
I just wish there was a video; maybe you know of one, that shows how to import from RR and program it that way. I paid for the subscription I might as well use it to my advantage. Thank you.
thedanderzone
Wisconsin
There’s also an option to import a Motorola Minitor 6 programming file into the PPS and it will automatically convert it over. I’ve found that it works okay, but you still need to add in and change around some of the information.
thedanderzone
Wisconsin
Thank you!
Of course! Hopefully those videos help. They helped me quite a bit when I first started to set mine up. If you need anything else, don’t be afraid to ask. I’m used to using several different programming softwares, but I always have to re-learn Unication software.
