G5 QCII Priority alert tones
cinsu
WT44
I feel like I'm losing my mind on this one. I am using a G5 VHF/800 and am having what I imagine is a programming issue. Yes, I have read the side bar. The system in this case is VHF conventional using QCII tones. What I am trying to do used to work fine prior to v2.
I have multiple tone pairs for multiple agencies that I work for.
  • I have the correct tone pairs in the Conventional Group ID List. I would like "Tone 3" to be used when the pair for agency 1 sounds and "Tone 8" to be used when the pair for agency 2 is used. I have configured this with alert mode Tone & Vibrate and selected the Alert tone for each agency.
  • Under Zone & Channel settings I have a selection for Selective Call. I have the tone pairs I have created under "Talk Group List". I see "Tone 3" and "Tone 8" under each respective agency tone pair. I have Priority selected for each as I also have several other tone pairs programmed as "off" so they get IDd but don't alert and another tone pair in Off Duty.
Initially I had priority alert tone under E11-2 set to none. With this the pager would not sound an alert for the QCII pairs I had selected Priority on. I changed this setting to Default Tone and now each agency alerts with default tone, not Tone 3 and Tone 8 as I have selected so now I'm confused, what is the point of having options for tones per QCII pair if it doesn't actually use that tone?
Ultimately I want to dynamically use on and off duty modes, with some QCII tone pairs in "Priority" mode with a different alert tone depending on the QCII pair. It seems as though I can't do that using the priority option?
On another note, while "off duty" and in selective call early this morning the pager opened squelch with no alert tone for a QCII pair that was selected as None in the Talk Group list.
hazrat8990
Wyoming
Since everything worked prior to upgrading, you definitely need to go back to the previous version of firmware. I have V1.35 if you need the installer file.
