tones
Salem NY
Hey group looking for some guidance. I work for a company that has an internal group that handles emergency response on a day to day basis. We have someone that monitors the phone for emergency calls and then radios us the call. What I want to achieve is prior to the call taker dispatching the call over the radio to us I want some sort of alert tone or tones like the warble tone, just to grab your attention prior to the radio transmission. So I need to know how do we do that? What do I need for equipment? We are currently using Motorola xpr 3500e radios with a Motorola repeater system in place for uhf . PLEASE HELP
Usually that is handled by the dispatch console, but it sounds like you don't have one.
If you are running these radios in analog mode, setting up a two tone page will let the person at the phone send a page that will trigger an alert tone on the other radios.
Or, have them lean on the DTMF key if the radios have a keypad.
northstarfire0693
North Carolina
We had the set up the OP is asking about at my previous employer. Our system was UHF conventional that used KW mobile for a base station and Moto portables. We had the mobile programed to do QC tones by pressing the orange button then keying the radio.
I dont know about the XPR series if its possible to set it up that way, but the OP would need the CPS and equipment to set up the radio
K2NEC
5F6
You're talking about evac tones, which the XPR series will not support
K4EET
Chaplain
Severn, Maryland, USA
Hi @NYRA_Fire_Marshal_C1,
One place that I worked at eons ago had their engineering team do the following. At the operations center, there was a base station that was connected to multiple in-building remotes. They put two remotes at the dispatch position. One was for voice dispatching. The other remote, the engineering team built an interface to the mic line for a warbler device. Worked like a champ although it was still a kluge job!
Just doing a quick Google search, this device might be a possibility. If somebody in your tech department can figure out the interface circuitry, you might be able to duplicate what was done eons ago in a commercial dispatch environment where the workers were missing hearing a call for whatever reason. Note that I have zero experience with this company or device.
Salem NY
Thanks, yeah no dispatch console. But the sync mic might just do the trick
