G5 TGID programming question
ltcmdrdata
Racine, WI
Good Afternoon all and Happy Holidays. Received a G5 for Christmas and for the most part no issues programming. Able to import trunking information from Radio Reference no problem. Question/scenario - using E7 of the software - Zone 2 knob position 1 I have a talk group 4977 dec/1371 hex. Trunk TG-Monitor, Priority Talk Group List has 4977/1371. No scanning. When on this channel I am receiving other trunking voice activity from other talk groups. I am sure its a simple setting in the G5 but have spent the last five hours looking through this forum and do not see a similar explanation. Thank You for any assistance!
K9KLC
Southwest, IL
What is this you're actually trying to receive? ie what system are you on?
K9KLC
Southwest, IL
Trunking TG-Monitor will scan all talkgroups active on the system, and ID the ones you have entered into the list with aliases.
Trunking TG-Scan will only scan the ones in the list.
I totally missed he had that instead of TG scan. Thanks.
K9KLC
Southwest, IL
I'm assuming then you don't have to add TG 65535 to the list any longer then? You can add 64 regular groups and put it TG monitor and it will scan for everything identifying the 64 you have in there?
Enjoi19
Ontario, Canada
Yep
This is not correct, if you have it programmed to monitor or you use 65535 you may only add 63 known TGs to your list. The G series pagers need that 64th placeholder for the unknown/discovered TG to be displayed and heard.
scanner92us
Somerset PA
I just tried this with my G4. On my County zone, on knob ch 6 filled with 64 TG, uprogrammed ones came through. It does Work.
I have Firmware 1.35 in it. I don't know if it's only some Firmware.
K9KLC
Southwest, IL
Ok thanks. That's what I had always been told.
K9KLC
Southwest, IL
Ok I'll try it when I get home. I have one that has 63 in it and the wild card I'll just add one more and eliminate the wild card and see what happens. Thanks.
