G5: Tone every broadcast
Heavyhaul
Montana
I'm trying to program my G-5 and now every broadcast starts with a tone I have to push a button to listen to the pager. Never had this happen before and I can't figure out what I did this time to screw this up. Been working on this for 2+ hours. What did I miss? Thanks in advance.
I believe what you are looking for is in this section, check the bottom three items in this part of the menu and see if they match the screenshot...
Heavyhaul
Montana
Well I did have to change those specific settings back for some reason it is still alerting me with a piercing tone and I have to push and hold the button on the left side of the pager to listen to the broadcast. No problems on VHF conventional channels just the P25 system I'm trying to monitor.
Check the second entry in that section, it should be NO. Unless you are using a BT headphones/speaker then turn off tab 11-4
Heavyhaul
Montana
Well now it's alerting with the piercing tone but after a second it's broadcasting the audio without having to push the button on the side of the pager.
I gave you the two basic fixes, now you would need to check TG and see if Tone Alerts are set for them in that screen.
Heavyhaul
Montana
Thanks I appreciate the help. I'll check that as well as check each step line by line.
hazrat8990
Wyoming
You can export your profile, put it into a .zip and post it so I can take a look. If you don't feel comfortable posting it here, we can do it via PM if you wish. Since you're new you wont be able to start a PM, but if you ask on here, I will send you a PM that you can reply to.
