GA State Patrol
mocman
LaGrange Ga 30241
I live in Troup county and seem to have all the locals except GSP.......anyone know the freq? Or how to import via arc500?
shadcall
Ormond Beach, FL
You would install them the same way you installed your local frequencies. It appears from the database that Troup County is on P25 digital. If your scanner cannot decode digital signals you will not be able to listen to them. Perhaps someone local can confirm if the GSP is using digital for this county.
rapidcharger
The land of broken calculators.
Chances are, when GSP is working in Troup County, they will switch over to the Troup County talkgroup on the Muscogee race-to-waste system for running licenses and responding to local incidents but also have their VHF for GSP dispatch.
DC
Carrollton, Ga.
GSP Troup County is on a conventional P25 digital system. If your scanner can't decode digital then your SOL. 154.7025 Nac:625
Happy Scanning
DC
mocman
LaGrange Ga 30241
I have a Pro 106 and a Pro 197 I assume they will pick GSP up......I assume I can select add in ARC500? Also how do I add the NAC or do I have to? Also here in LaGrange we have a GSP Post.
shadcall
Ormond Beach, FL
In ARC 500 when you select the frequency the NAC will automatically be added to the SQ code column. The SQ mode column should have P25 in it but that also will be filled in when you add the frequency.
