budbrur
Help, I am new to scanning project 25 systems.
I am trying to scan York County, VA. Everything I hear is garbled. Any suggestions?
solid core or stranded wire?
ofd8001, thanks for that wonderful post! I think I'm having this same issue using a BCD996XT, the channels that I'm listening to are not Encrypted. Do you have any advice for this model scanner?
So what happens when a police car is in the red area? They receive nothing too?A picture being worth a thousand words, see the image below which depicts a 3 site simulcast system. The green areas should have clear audio, yellow may have garbled audio (overlap of multiple sites) and the red area may receive no audio at all.
So with P25, you need expensive and complex radios to deal with digital simulcast issues, on top of the whole migration to digital costs.This isn't an issue with actual users on the system. The radios they have are much better than scanners on dealing with simulcast systems.
As an illustration, the video from a smart phone is reasonably decent, but nothing like the broadcast quality seen in a "professional" camera such as those used by television news photographers. There are more things "under the hood" of the broadcast camera and as such there is a huge price difference.
A similar principle holds for scanners versus "real" radios on a simulcast system. There are things "under the hood" of a public safety radio that deal with simulcast issues better than a scanner will. Of course there is a similar price differential - a scanner costs around $500 where public safety radios run between $2,500 and $5,000.
Analog was much more forgiving.
I know it's a whole other topic, but still trying to understand the benefits of going digital...
Sigh, you need a receiver designed to properly receive the wave form you are trying to listen to.
The problem is that motorola simulcast systems do not transmit in C4FM, they use CQPSK. This is significant, while the subscriber radios can decode this waveform, it is because their receiver is designed much differently than scanners. The method used by scanners to get the data from the signal to the decoder is not an optimal way recover data from a CQPSK waveform. Because of this, people have difficulty with LSM simulcast systems. It is also why subscribers do not have the issues that scanners do.
It's not 'special' it is different, like SSB receivers are different than FM, than AM, than ACSB.
Well, I guess I'm learning. I thought when Uniden says they can receive P25 Phase II, then that's that and everything's golden. Now I hear Moto uses some different design, so it's more complicated, and there's problems.
As if a $500 receiver is not expensive enough, now I hear to properly read these systems the price would be even higher.
