DaveH
The site SHOULD NOT be listed as one number in the DB. The "1" should be in the RFSS column and the remaining numbers in the Site column.
If you look at the Gatineau system (Gatineau Trunking System, Gatineau, Quebec - Scanner Frequencies), it is programmed correctly in the DB. The HQ and RENIR systems are listed completely wrong. (The separate entry for the Montreal Fire part of RENIR is corrected.)
No argument from here, just noting that if it were reduced to one block, 1060 (or 001060) would have
been more numerically (but not formatically)(is that a real word?) accurate. To what extent this affects
downloading I'm not sure, doesn't affect me at the moment.
Just slipping in another datoid, Site 131 (001-031) looks a lot like Huntingdon, which comes in here
fairly often (but not at the moment, so can't confirm).
Dave
