GD-77 and Windows 10 USB driver issues.
mojobreakfast
I have a GD-77 I bought a year ago and never got around to using. Firmware version of the radio is 2.6.3. So I want to finally program this thing. I plug in the programming cable into my Win 10 PC and the radio, turn the radio on, and in Windows Device Manager the radio shows up as "Unknown USB Device (Device Descriptor Request Failed)".
Where the heck do I find the right driver for this radio, or is there something else wrong here (faulty cable?). There is no driver included with the disc that came with the radio (CPS software) and there is no driver I can find for GD-77 + Win 10 on the Radioddity site.
popnokick
Northeast PA
The Radioddity programming cable does not require a separate driver and should be recognized by Win 10 automatically ("Plug n Play"). One of two things is likely wrong: 1) Your Win10 installation has not been updated to the latest / most correct updates to support the cable; 2) you have a defective programming cable. Try the cable in a different Win 10 computer and see if it works.
mojobreakfast
Yep, you are basically correct. This was my fault. The bad USB device I saw in Device Manager was completely unrelated (different broken device in my computer). I was expecting to see a new COM port come online in "Ports (COM & LPT)" when plugging in the radio. This is not what happens. Instead, a new "USB Input Device" appears under "Human Interface Devices".
popnokick
Northeast PA
Glad you found it! And DO perform the update to the latest version of the GD77 firmware / programming software. Makes a big difference.
