General Motors Canada DMR
bigcam406
oshawa,ont,canada
was doing a freq search this afternoon with my 898t and found a very strong control channel of unknown mode. searched database but couldn't find anything. any ideas?
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Spectrum Management shows a license (CFB562) for a DMR system for General Motors with the transmitter located at 900 Park Road South.
Frequencies listed on the license are (in frequency record ID order):
939.02500 MHz
939.08750 MHz
939.01250 MHz
939.06250 MHz
939.05000 MHz
939.11250 MHz
939.12500 MHz
939.07500 MHz
939.10000 MHz
939.03750 MHz
The license was just issued/effective October 1, so the system is probably in its infancy.
Strangely, the license conditions warn that it is GM's responsibility to ensure this system does not cause intra-system interference with their other systems in Ingersoll and St Catharines.
VE3RADIO
Planet Earth
939.02500 MHz
939.08750 MHz
939.01250 MHz
939.06250 MHz
939.05000 MHz
939.11250 MHz
939.12500 MHz
939.07500 MHz
939.10000 MHz
939.03750 MHz
Yup this is correct.. its a connect plus system.. I have been watching it for a few weeks now.. no talkgroups seen yet.
Jay911
Curious... is the order I listed the freqs in, the correct LCN order?
If so, then it might become useful when looking up licenses. If licenses are now being registered in what amounts to LCN order, that might save people a lot of time.
bigcam406
oshawa,ont,canada
thanks guys.it so happens i live right across the street from the plant so that explains such a strong signal.thanks again.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
I have staged this trunk system and if people choose to contribute information, I can release it to the database.
VE3RADIO
Planet Earth
TYPE, SYS, SID, LCN, FREQ, CC
Con+, 395, 73, 01, 939.0125, 1
Con+, 395, 73, 02, 939.0250, 1
Con+, 395, 73, 03, 939.0375, 1
Con+, 395, 73, 04, 939.0500, 1
Con+, 395, 73, 05, 939.0625, 1
Con+, 395, 73, 06, 939.0750, 1
Con+, 395, 73, 07, 939.0875, 1
Con+, 395, 73, 08, 939.1000, 1
Con+, 395, 73, 09, 939.1125, 1
Con+, 395, 73, 10, 939.1250, 1
Ask and it will be provided.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Thanks, Matt!
Here ya go, everyone: http://www.radioreference.com/apps/db/?sid=9017
Forts
Ontario, Canada
Just an FYI this system uses the same frequencies as the GM CAMI Automotive plant in Ingersoll. Same network ID, different sites. The CAMI system went live about a month ago, give or take.
DaveH
Ottawa, Ont.
How come, given that it's DMR, we are seeing only one LCN per RF channel, whereas DMR gives two...
"Real" LCNs should be 1-20 .
Some DMR systems in RR DB show the RF channel duplicated, with consecutive LCNs.
Dave
VE3RADIO
Planet Earth
I wrote it out for the scanner users.. it should be like this:
Con+, 395, 73, 03, 939.0250, 1
Con+, 395, 73, 05, 939.0375, 1
Con+, 395, 73, 07, 939.0500, 1
Con+, 395, 73, 09, 939.0625, 1
Con+, 395, 73, 11, 939.0750, 1
Con+, 395, 73, 13, 939.0875, 1
Con+, 395, 73, 15, 939.1000, 1
Con+, 395, 73, 17, 939.1125, 1
Con+, 395, 73, 19, 939.1250, 1
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Jay911
At the risk of opening up a can of worms (similar to the one I cracked open a few days ago), does this seem like a good candidate for having one RRDB entry with multiple sites in different counties?
VE3RADIO
Planet Earth
I agree, they are all the same network ID.. just sites are different.. and I would not be surprised to see linked talkgroups when the system starts being used.
VE3RADIO
Planet Earth
I also noticed you have a 2 mile radius setup.. I can hear it from much further.. at least 5 miles (perhaps 2 miles is what IC licensed it for)
Forts
Ontario, Canada
I can't see talkgroups being linked from one site to another... don't know why they would need that. Might be interesting to see if some of the talkgroups are the same though (ie security, ERT etc). The CAMI site also uses a ton of private calls (carryover from the old iDEN system).
VA3DBJ
Ontario Database Admin
I am not picking it up in Bowmanville. :(
Forts
Ontario, Canada
I fixed a frequency omission for CAMI and added a few talkgroups. All the activity I've seen has been on groups in the 7200 range (7201 - ~7040), plus as I mentioned earlier extensive use of private calls.
mbstone99
Hamilton, Ontario
I was down in St Catharines today and was park across the GM Plant there and noticed that they are using the same Con+ system .. I would probably gather that the frequencies there are the same as the ones at the other plants here in Ontario..
939.0375 Con+ CC 1 Net 395 Site 74. didn't hear any TG's active in the short stay in the area though.
Matt
