Georgia Users: Info when submitting data
wise871
N.W. Florida
FYI, some of you have submitted new talkgroups to be entered into the database. If your using an XT series scanner, please make sure that you have Status Bit set to ignored which is the default settings for the scanner. If you have it set to Yes- the scanner treats all received ID's as unique ID's and not the actual ID.
Since the Radio Reference system is designed to use the actual ID anything else will cause an error when we enter your information because it is not the true ID. Then the ID's you have will only work on your scanner.
Just a tip to make life easier for all of us. Thanks again for the submissions.
