Greetings,
I am tearing out my hair trying to get SDRTrunk going with Broadcastify Calls. I downloaded SDRTrunk v0.5.0 Alpha 2 and use two dongles since my target radio system's bandwidth is just under 3 MHz. I was able to get it going somewhat, but I have a few problems I am trying to figure out.
-- The program intermittently freezes up. Below is a screen shot of the command window. I am not that knowledgeable with computers to understand what the errors means. In addition, once in a while I get a "Java heap space error".
-- The next problem that I have is that when I do have it up and running, it seems like its missing several transmissions as the "now playing" tab shows no transmissions, but yet hear transmissions on a regular scanner. It also sometimes will get partial transmissions. I have a portable scanner antenna attached to the dongle so I don't necessarily think reception is the issue.
-- One other issue I have been having I can't get the dongles/tuners to stay parked on one frequency. My target system is between 851-854MHz. So I have one dongle set at 852MHz and the other set at 853MHz. On the tuner tab I can watch the frequency start bouncing around between 851.0625 and 853.5000 and the channel column will flip between locked & unlocked.
Any help or tips that can be provided would be great. Unfortunately, I am rather a novice with the whole SDR scene.
Tim
Tim
