Getting started in Wiki editing
phask
zanesville
So how does one edit the Wiki? Is there a Wiki on how to edit a Wiki? :)
Glancing at some of those I already see outdated or erroneous info.
We have quite a number of FAQs in our wiki now - and more to the point, we have 4 such FAQs set up for the newest generation of scanners. These FAQs are centered around questions that keep on coming up time and again, or have answers that are otherwise hard to locate.
While I've done the work in organizing a lot of this, the details comes from you If you have a topic that isn't covered, or you have found an answer to a question not documented anywhere, please consider adding it to the FAQs. We have one each for the DMA, keyboard driven, GRE/RS PC driven and Home Patrol scanners as listed below.
Uniden DMA FAQ - The RadioReference Wiki
GRE/RS Object Oriented Scanners FAQ - The RadioReference Wiki
GRE/RS PC Object Oriented FAQ - The RadioReference Wiki
Uniden Home Patrol FAQ - The RadioReference Wiki
If you're unsure as to how to add something, please ask me, Bob W9RXR or bezking. And remember, the devil is in the details. The more detail you add, the clearer the answer sometimes becomes.
best regards..Mike
phask
zanesville
I guess you mean here :
Quick guide to editing pages - The RadioReference Wiki
- without a direct link - who knows -
Om that page it states " Simply click on the "edit" tab at the top (or the edit link on the right or bottom) of a Wiki page"
On my view - either Firefox or Chrome - there is no Edit tab or link. Even using the search term edit - it finds nothing.
Suggestions?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If it doesn't say 'phask' under the PERSONAL TOOLS on the left, you need to log in.
If you're not in the wiki user database, that's something I think - it's been too long - you can email Lindsay to add you
Mike
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Suggestions?
You have to log in to the Wiki first before you can see all that stuff. If the wiki page is broken up into sections, the [edit] button is at the far right of the title for the section.
SteveC0625
Mike
I don't believe there's anything that has to be set on the host end.
You just log into the Wiki using the same username and password that you use in the forums.
QDP2012
The Wiki login is case-sensitive whereas the forums login is not. If you want the Wiki-engine to keep a consistent history-log of your contributions, be sure to use the same upper/lower-case every time you login to the Wiki.
Hope this helps,
phask
zanesville
Thanks all - I did log in and still nada. Just went back in and now it's there
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you need help with editing something, start a new thread, and someone will be sure to jump in to help.
And don't be afraid if you 'mess up' an article - we've all been there, and there's a history that's automatically logged, so an article can be reverted quite easily
Mike
