Getting UniTrunker 2.1 sorted out
dkcorlfla
Orlando
I read the post #482808 ( Unitrunker voice vfo stays parked) but I still can't figure it out. I'm not seeing anything in the logs and VFO2 has no signal.
I can hear the control channel clearly and if I fire up SDRpp and DSDplus I see it's a +DMR system and I get voice decodes on it from time to time.
I'm missing something!
dkcorlfla
Orlando
Unitrunker does not decode DMR.
Looks like that was one thing I missed, bummer as there is a lot of DMR around here.
Found a P25P1 control channel but still nothing. It's not real strong so maybe that's part of the problem.
Will try to find a real strong channel of one of the supported formats but I need to take a break from it for a while.
Look at the above post from @dave3825 and adjust using warp, you want to get the WINDOW number as close to 0 as possible.
I strongly urge you to join the Unitrunker Google Groups and look through the posts, they are full of very good information.
dkcorlfla
Orlando
Thanks for the help, got it sorta working. Found a P25p1 system using the RR database and SDRpp and DSDp and when I set the frequency for VFO1 to what I had found (769.080) Lots of stuff started to show up.
Looks like the main thing I missed was the supported formats of UniTrunker. As soon as I set the frequency to a supported format I started to see action :)
I will take my questions on VFO2 to the unitrunker google groups.
