As of about 9:30 AM on Sunday, April 12, the Fredericksburg LCRA 700 mHz performance has been troubled. The signal is strong; no audio is coming over it.
The setup here is a SDRPlay RSPDx using SDRTrunk program. Additionally the Uniden BCD536HP is being used. The radios are within 1 mile of the LCRA Schneider Hill Fredericksburg repeater. Both use outside antennas with good performance over the past years.
The SDRTrunk shows a very strong signal on the control channel yet the program will not latch on to the control channel. The 536 S meter shows full bars but no audio with an exceptional blurb coming through. The “Analyze” function of the 536 indicates good signal and good quality but there is no audio present when a transmission is heard over the Luckenbach tower.
The SDRTrunk and the Uniden will both connect to the Luckenbach Tower which is about 15 miles away and any Gillespie LE or Emergency operations that are on the Luckenbach Tower are heard fine. (Most Gillespie traffic is also over the Luckenbach tower as it serves the eastern part of Gillespie county.)
The SDRTrunk with the SDRPlay has been tested on another computer with the same failing results.
Also the op25 program for Linux is used on a third computer with an RTL-SDR but the results are the same as above. A signal is present for the Fredericksburg Schneider Hill repeater but the op25 will not latch on to the signal nor can any audio be heard.
The SDRTrunk input data for Fredericksburg has been re-programmed in for all the various scenarios. This was done in hopes of finding if LCRA had changed something. Changed were Phase I, Phase II simulcast, Phase II TDMA both channels, Phase II TDMA individual channel with no improvement.
A general receive radio (not a trunk radio) was used to tune to the control channel to see if a loud buzz was present and the signal was present and the computer digital buzz was heard.
(Note: Sunday April 12, about 1700 hours (5:00PM) the Fredericksburg Schneider Hill repeater seemingly worked for about 30 minutes but quit)
Is anyone else experiencing such?
Edit: After I posted this, the Fredericksburg Schneider Hill is being received on the 536; the SDRTrunk will not latch on to the control channel nor receive. The Luckenbach tower is working fine. The SDRTrunk does have all the frequencies input and with the display of the RF signals, it is verified which is the control channel. This is to verify that the SDRTrunk is seeking the correct control channel.
