GM-15Pro Programming Help
Unidener
I'm back with more Newbee questions.....
The only software I have been able to find for programming is the Chirp Next but it does not list the GM-15pro and others have said it will work with the Radiodity GM-30 but neither are in the list!
Please help!
K4EET
Chaplain
Severn, Maryland, USA
Please help!
Doesn’t Baofeng offer the programming software on their website for free? I can check tomorrow. For now, take a look at this thread:
Gotta hit the sack. I’m an early riser…
73, Dave K4EET
Unidener
73, Dave K4EET
Looks like Baofeng offers CHIRP which I have but it does not support my GM-15Pro, others have said that it's the same as the GM-30 so I can read from the GM-15Pro but I'm hesitant to program it. I guess I should try and worst case I can reset the radio to factory specs.....
Thanks for the reply and help and I really wish I could find a good video for programming manually and with CHIRP.....
I've been dealing with some stomach issues that is messing up my sleep....so my brain is only working at 20% o_O
808Beachbum
The free download for Radioddity GM-30 works perfectly for the BF GM-15 Pro. In fact, the fastest and easiest connection process I have encountered in the last 10 plus years as a Ham. To be clear, I am using the Baofeng programming cable...can't speak to any other cables. Also, I did not need to load the driver that came with the cable, on currently updated Win11. The cable was immediately recognized.
With the radio off, plug the cable into your desktop usb, and the radio. Open the (installed) app. Turn on the radio. Select from the file menu, Program >> Read from Radio (you want to save the original factory settings first).
After closing the two "OK" dialog boxes, you can start making changes or additions. Start with the "Channel" branch of the nav window. It will not allow you to enter freqs that it is not authorized to RECEIVE, but, for example, I programmed the Marine VHF channels as well as several local HAM repeaters. If you actually have access to GMRS repeaters, the set up for those channels is not super intuitive in one regard: When you are on the "Channel" Spreadsheet, the far right column just shows ">>", which, as the column header suggests, gives you "more". Surprise! This is where you can easily change your Tones, channel spacing, frequency step and more. Nothing to it. My ONLY gripe about this program is that it would not let me "paste" a column of freqs, for example. 88 Marine channels and their names take a fair bit of time to key in, even on the desktop!
One additional change I made was the standard channel names. Rather than "Ch- 1", I changed to "CH 1H", to much more easily recognize this was a high power channel (vs. L for the low power channels). I also just deleted the RPT DIY channels, as there are no repeaters in my area. If I find any "open" GMRS repeaters it will be easy enough to set them up another time.
Just starting out, you likely will not need to edit anything on the VFO A and B branches...just skip to the General Settings branch, where you can turn off the "voice", "roger beep", "beeps", and enable FM broadcast receive, as well as "Dual Watch".
Once you are satisfied with your changes, FIRST, save the file with a new name. I usually just use "update 041124" or "update2 041124" for example. You should have a separate file for GMRS, and possibly a subfolder for all updates only. No need to close the app if you have additional radios to program. You DO need to click on Program >> Write to radio to make the changes on the radio.
Turn off the radio. Unplug the cable. If you bought a multi-pack of 2 or more radios, plug the next one into the cable, turn that radio on, go to Program >> Write to radio.
Unidener
Thanks for the help....got the radios working and tested with a nearby repeater!
One last question......There are other channels such as 55 and above that I could program but the TX frequency is greyed out....any idea why or is there a workaround?
Thanks again for the reply!
k9wkj
where they make the cheese
from page 10 of the manual
• 220 Programmable Scanner Channels (Receive Only)
so you can program Amateur,marine,utility,public safety frequencies
and use it as horrible slow scanner
808Beachbum
Those are available for receive monitoring ONLY. You cannot transmit on non GMRS freqs. As I mentioned previous, you can program VHF/UHF Ham freqs, Marine VHF freqs, and many others that may be useful for gathering local intel during major incidents; or just to familiarize yourself with local activity that may lead to upgrading to a HAM rig and license.
Unidener
I do have a Ham license....I thought I could program the GM-15pro to use 2m 70m as well.....
tomk62
Charleston, SC
What makes you think that?
Right in the specification it says you can only Tx on GMRS
Unidener
My non-working brain.....I've looked at so many....guess I was wrong.
Having probems finding replacement batteries for my 2m/70cm HTs so I thought I would kill the bird:oops:
Guess I'll look for another combo Ham GMRS....thanks for pointing it out but I would eventually have figured it out....only been working on programming and GMRS...
BUT getting back to my question is WHY is TX blocked on channels (above 29 or 39?) even for GMRS? I know they are already there but I would like to have some custom ones for my wife to easily find (set with tones) so I don't have to change an already programmed channels..
Thanks for the reply!
v_pb
Please help!
I use "Baofeng UV-13Pro" profile for my Baofeng TP-8R, which is analog GM-15Pro and Radioddity GM-30 I believe.
sempai
Iowa City, IA
I used one of these and used the UV-13Pro option with my Baofeng USB><BatMic adapter and it was great. Perfect radio for handing another family with kids that might try to TX on the county ambulance dispatch or something.
with kid radios i either disable TX entirely on anything that can get them into trouble easily and/or set to the lowest output and grit my teeth. The RadioOddity software wasn't bad either but I already have my system template in Chirp and prefer that for easy configuration of a new radio. thankfully there are nice gmrs-first HTs out there!
rf_patriot200
Freeport, Illinois
Ham and GMRS cannot legally be done in the same radio. Different FCC Parts in the CFR.
It IS Now, in several different radios. a Keypad code is entered to allow 1. Ham 2. Gmrs/frs or 3. Unlocked, allowing Murs, Gmrs, And 2m/70cm.
The TID radios do this, as well as Wouxun radios. They Somehow have valid FCC certifications too. :rolleyes:
Darren418
I just converted my Baofeng GM-15 Pro from GMRS to 2m/440 ham. This conversion also allows transmit covering the gmrs freqs if that's your thing. I just simply have two radios, one in orange for GMRS and one in black for 2m/440 ham.
The video is on the Radioddity GM-30, but it works just the same on the nearly identical Baofeng GM-15 Pro.
sempai
Iowa City, IA
are you referring to a "test" or "factory override" or some sort of easter egg, or are these documented procedures in the manual as if they're features.
Cuz my gmrs-pros and vero n76 can unlock other frequency ranges too, but they involve secret handshakes and easter egg tapping or holding keys while power cycling the radio like you're showing off at In and Out Burger by ordering a 4x4 and Neapolitan?
hill
Middle River, MD
I know this is an old tread, but ham and GMRS can indeed be used in same radio.
My Kenwoods TK-390, TK-3180 and TK-5310 all have GMRS and ham 70 CM frequencies in them.
K4EET
Chaplain
I was basing my comment on this paragraph:
If I am mis-reading this paragraph, I’m sorry. Perhaps somebody can provide clarification.
95.655 doesn't exist any more. You might want to pull your data on FCC rules directly from the Code of Federal Regulations page:
What you want has been moved to 95.1761 Federal Register :: Request Access
§ 95.1761 GMRS transmitter certification.​
(a) Each GMRS transmitter (a transmitter that operates or is intended to operate in the GMRS) must be certified in accordance with this subpart and part 2 of this chapter.​
(b) A grant of equipment certification for the GMRS will not be issued for any GMRS transmitter type that fails to comply with the applicable rules in this subpart.​
(c) No GMRS transmitter will be certified for use in the GMRS if it is equipped with a frequency capability not listed in § 95.1763, unless such transmitter is also certified for use in another radio service for which the frequency is authorized and for which certification is also required. No GMRS transmitter will be certified for use in the GMRS if it is equipped with the capabilities to operate in services that do not require equipment certification, such as the Amateur Radio Service. All frequency determining circuitry (including crystals) and programming controls in each GMRS transmitter must be internal to the transmitter and must not be accessible from the exterior of the transmitter operating panel or from the exterior of the transmitter enclosure.​
Paragraph C says:
unless such transmitter is also certified for use in another radio service for which the frequency is authorized and for which certification is also required.​
There are radios on the market that have BOTH Part 95 and Part 90, so totally legal under this paragraph to have a radio that does Part 90 LMR -AND- GMRS, if it has Part 90 -AND- Part 95 certification.
But I think this is the part you are referring to:
No GMRS transmitter will be certified for use in the GMRS if it is equipped with the capabilities to operate in services that do not require equipment certification, such as the Amateur Radio Service.​
In my individual opinioin, worth exact 2¢ in official internet money, that's saying that the GMRS Transmitter will not be certified if it has frequencies in it that are not GMRS.
Where this comes from, in my memory, was there was a large company selling radios that had both Marine VHF and FRS in them. I think the FCC was trying to fix their mistake of 'dual certified radios' when they did the dumb FRS + GMRS thing. Specifically, not to confuse consumers with an FRS/GMRS radio that has access to all those cool "extra" VHF marine channels as an extension of the GMRS radio service. As we know average Joe Consumer does not understand radio and doesn't understand that just because they bought a radio off Amazon that they cannot legally use it.
A legally licensed end user who takes their Part 90/Part 95 certified radio can program amateur radio frequencies in as amateur radio does not require type certification on the transmitters.
hill
Middle River, MD
I think the rule was written for consumer type GMRS radios getting certified by FCC and not really Part 90 radios that also have Part 95 certifications like the TK-3180 or TK-390.
With Part 90/95 users can really program with many frequencies outside of GMRS, as long as the end users have licenses in all radio services used.
The hard part is not putting out the wrong callsign on wrong service. Been a ham for much longer and only have been on GMRS for just over a year. Many of the people on both ham and GMRS in my hold both licenses, so all understand if you accidentally use the wrong one occasionally.
