GM300 Programming past 470 to 480 ?
Ghost8546
Bedford, MA
My UHF unit has the band limit of 470, but I have programmed 471's and 2's. Is there some reason I can't get to the 480's ? Is that just too far, or is there another way of doing it ?
cmdrwill
So Cali
The GM300 was NOT designed or FCC type certified to transmit above 470 mHz.
Problems is with TX power control and deviation settings in the microprocessor system do not support anything above 470 mHz.
Shift
The Shift Trick, if that's what you're doing, will only work for so far each way.
I never could get a 450-470 to get down to 423, no matter how many I tried.
Ghost8546
Bedford, MA
Gm300
Yes i was trying the shift trick.. Like you said I only got so far. Thanks
