GMRS computer programming (Wouxun)
hiegtx
Dallas, TX
Power is on and connection are good. Also drivers are up to date, still not communicating. Any idea?
I can't read that 'error message'. What is it saying?
And what, specifically, do you mean it is "not communicating"?
No reception? On an SDS or x36HP scanner? (Do you have the "Other" Service Type enabled?)
Or are you referring to programming a Wouxun walkie-talkie? (If it's a Wouxun, I'll step back; not familiar with those at all.)
JamesBrox
Santa Rosa County, FL
Yes sir, it's GMRS. It's saying, "Failed connection" Figured I try this forum because it is computer aided programming and the radio does have scanning abilities lol. Thanks anyway Happy 4th.
JamesBrox
Contact Admin and see if they can move your thread to Budget and Entry Level Transceivers.
What specific radio model are you working with and what is the specific error? Sure someone can then guide you to get your Wouxun programed.
The KG-1000G and KG-1000G+. I can't the software to communicate via the Wouxun programming cable to neither radio from the computer. Ok. If an admin is seeing this, please move to the appropriate thread. Thanks
Border_Dave
Bellingham, Washington
Your programming cable isn't plugged into the jack that the remote head plugs into, is it? If so, it shouldn't be. It should be plugged into the jack on the side of the radio with the rubber cover over it.
JamesBrox
Out of utter embarrassment, I refuse to answer that. LOL! Talk about a "duh" moment. Thank you for your help, sir.
