The following two points are what this post revolves around:
I've been trying to find out more about this insanely strong signal coming from somewhere nearby. I did a search on the frequency using the database on this site as well as the FCC database. Both point to the active callsign WNYN376. This active license is supposed to be using either P25 or NXDN. What is being transmitted is DMR.
As you can imagine, I was confused. Then, just out of pure luck, the station identifier was transmitted. It was KNFT47Z. I searched the databases again and came up empty handed. I've attached the recording of the station identifier for your enjoyment as it doesn't appear to be programmed correctly as you will see below.
I then decided to look at inactive licenses. An inactive license with the callsign KNFT477 showed. No, that is not a typo - see above. Sure enough, the emissions pointed directly to DMR. One of many questions I have is: Is it common for government entities, in this case a school system, to let their license expire (assuming unknowingly) and continue to use equipment? The license has been expired for two years.
I just found this interesting and thought I would share. Does the FCC give out rewards for being a snitch?
- Frequency: 416.9 mhz.
- Callsigns: WNYN376, KNFT47Z, KNFT477
