SDS100/SDS200: GPS icon
JobabeBob1981
Cornwall NY
I have the GPS unit to go with the SDS100. When utilizing the GPS is the Icon supposed to be lit up on the screen?
dave3825
Suffolk County NY
You may have to change the baud rate in the scanner settings. Pretty sure it should be 4800. As long as you did not remove the icon in the display editor (if even allowed), it should display.
tvengr
Well Known Member
Baltimore County, MD
What model GPS receiver are you using? If it is the square receiver with the RJ11 connector, the baud rate should be set to 9600 bps. The scanner default is 4800 bps.
JobabeBob1981
Cornwall NY
Thank you for the responses.
What do you mean change a couple of its fields? What coordinates should I plug in? My location?
I have the GPS sold by Uniden from the SDS 100?
dave3825
Suffolk County NY
You can have the scanner display latitude and longitude on the screen based on the location provided by the gps. It's so you know your locked onto the satellites. You just set it up in display options and the gps does the rest..
dave3825
Suffolk County NY
No. Set up your display to display latitude and longitude. Then after you plug in the gps, and it sees satellites, it will populate the screen with your location. If using full database, just go in and set your range to like a mile or two and it will scan everything based on what service types you have selected. If your using favorites lists, you would need to set Location Control to on.
dave3825
Suffolk County NY
From on the scanner, go into settings and display settings, and look for customize display, and it should be able to change there, or read the scanner into Sentinel, and open the display editor and click on those two areas in the picture that I posted earlier, and It will allow you to set longitude and latitude. Then write to the scanner.
