gr1225 repeater programming
gizmp
baldwin park ca
What do i need to program my Repeater. I know i need a programming cable, but i heard i also need a attachment go with it? and I guess i need the software for it. but what i read that its hard to get other then pay the razzu of money to Motorola. but is there a third party software that can do it?
I also want to add a module which i brought a long time ago but misplaced it somewhere in my garage, (cant remember what's it called) but once installed I can have multiple PL codes and other features.
currently right now my repeater is up on the GMRS band.
i haven't used it as much, but a few years ago i tested and came across with another repeater coming up so I might need to change my PL for it
tdeater
Fremont, MI
You will need a M1225 ribless programming cable. They are pretty easy to find on line and on ebay. You will be programming it trough the front mic connector. Motorola Programming Cables - RIB Box- Ribless - USB- 2WayRadioParts.com
Not sure you can get the software from Motorola anymore, I think that radio series was end of lifed a while ago. I don't know of any 3rd party software. Again, not hard to find googling around. I think though you will need a slightly older computer to read the repeater though, but I am not completely sure. The software is windows based.
The other module would be called a controller. There were a few different ones offered by a couple of different companies. For basic GMRS use, the built in controller would work fine.
Project25_MASTR
TX-COMU
Texas
tdeater is spot on on his recommendations. The RSS (4.0 was built for XP) will only run effectively on a 32 bit machine and Motorola canceled the repeater about a decade ago. I haven't seen the RSS on MOL so it's likely NLA from Motorola.
nc700
If you haven't been able to get anywhere on this email me !
Sent from my SM-J327R4 using Tapatalk
Pittsboro IN
I remember having to run an XP virtual PC in win 2000 / 7 to program the 1225. At that time Microsoft sold the VM program which they later gave away.
Mcore probably remembers the R100 repeater and the horrible UI to program it.
Project25_MASTR
TX-COMU
Texas
Professionally, I've never dealt with the R100 (doesn't mean I haven't messed around with it). My work rule of thumb is if I can't support it through my issued computer I'm not going to support it (regardless of what corporate policy is).
The reason I say that, it got to the point where I was having daily crashes on the computer I was issued prior to the buyout. New company promised new computers (it was 6 years old at that point when I got it). 8 months in I started having daily crashes so I continuously put in support tickets until some one said, "looks like it's time you request a new computer." So I did and specified Windows 7. Took 4 months for that to get "processed" and what shows up is a Windows 10 laptop that is too big to put on a rack shelf with accessories connected and barely fits in my laptop (went from a 13" to a 15").
Where I was able to program Pro series, Astro series, MTR2000s and 1225's in the Windows 7 machine using XP Mode (note, issued laptop was 64 bit, personal laptops are all 32 bit and have no issue in Windows 7)...I can no longer program those radios on the new machine (and we still have a ton of customers using those radios).
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Last I looked, the Windows version of the programming software was still available on MOL in the Discontinued area. Version 4.0 is you want.
cmdrwill
So Cali
You are right down the road from me, glad to help. We STILL work on those radios!
marcotor
I ♥ÆS Ø
Sunny SoCal
There are users here who are local and can assist you with your programming, just give it a little time and they will come around.
You may want to consider not putting it on 462.600/625/650/675 as are all pretty well covered in the basin with repeaters, with at least six repeaters on 600 alone. PL/DPL helps, but a repeater on one of the other channels (550/575/725) might allow better coverage for you and your users. The Lukens 700 repeater is now no more, so that could be a choice as well.
Obviously you can do what you want, as there is no frequency exclusivity on GMRS, that's just my nickel :)
