GR1225 repeater
matty909
Fontana, California
I have a GR1225 when I power on i get the “beep” fallowed by a “bonk” so I know somewhere there is a error. When I attempt to read I get a error message. I have to program by setting up a codeplug from a different 1225 and clone which it does fine with no issues but I’d rather try to fix it so I can read/write normally. Someone had told me somebody probably wrote a bad codeplug I should try hex editing a codeplug to reflect my units serial number and write to the unit and problem fixed but I would like more insight because I’m not familiar with this older unit
Error I get when attempting to read is:
Error number 58 has occurred
Radio codeplug error
Option was aborted
matty909
Fontana, California
Fixed
Using RSS1225 V4.0 I read radio for service under the service tab. Repeater did read but acted like it did not and gave error code 58. I changed 1 setting by 1 value so I could the write the data back, the repeater accepted the write and rebooted giving me just the power up “beep” I did not get the immediate “bonk” this time so I so I tried reading the repeater programming and it worked without any problems I saved the file and attempted to write and the unit accepted the programming without any issues and no longer getting error 58. I went back to the service tab and changed the setting back and haven’t had any issues yet.
I’ve had this for 4 years now and assumed one day it would brick itself but I guess there’s more fight left in this box
