DonS
EDACS and LTR are 4 blocks each.jpryor said:Each object takes up a specific number of Object ID "blocks":
CONV - 1 block
TGRP - 1 block
TSYS - MOT/P25 10 blocks, EDACS 5 blocks, LTR 5 blocks
CONV - 1 block
TGRP - 1 block
TES said:Sounds like a lot of work. The latest release of Win 500 allows me to manipulate and assign Object ID's at will.
DonS said:EDACS and LTR are 4 blocks each.
jpryor said:Overall it is still better off that the traditional banks and channels of the 96/97, but just does not have the sub-grouping capability of the 396.
Doubtful it's your issue. Myself and others are having the same decode issues.mancow said:Just for info I did hear back from GRE and am in communication with them. They have been very responsive to the issue and are doing all they can to help me though things here.
I'm confident they will make things right if it ends up being something other than a stupid mistake on my part.
bonus1331 said:Again, how does this get past the beta testing?
DaveNF2G said:Some thoughts...
"Subgroups" - can't you create an object that simulates the GQK style of operation? Like, say, a fire object and a police object. Then you can lock out the police object if all you want to hear at the moment is fire calls. Am I visualizing this correctly?
Direct channel access - some have mentioned this already in terms of being able to jump directly to a specific frequency or talkgroup as we used to be able to do on "normal" scanners. Here's another GRE feature I miss on my Unidens, and apparently will also miss on the PSR-500 - the TUNE button. I like being able to punch in a frequency and mode and just sit on it for as long as I want without having to go through a full-fledged programming sequence.
Is there any function on the PSR-500 that works this way?
bonus1331 said:Doubtful it's your issue. Myself and others are having the same decode issues.
DaveNF2G said:Here's another GRE feature I miss on my Unidens, and apparently will also miss on the PSR-500 - the TUNE button.
Russell said:For Direct Channel Access you use the Object ID. If the talkgroup object you want is stored at 0368, the press MAN 368 ENT, and you will be taken directly to that TG or Freq. You kind of have to remember object addresses, but it works great. This number is listed after the Scanlist number in the upper left hand corner while scanning, e.g. 10-0368. It works great.
Russell
kikito said:Well, a quick report from me:
The PSR-500 is tracking our ALMR P25 9600 VHF trunked system perfectly. http://www.radioreference.com/modules.php?name=RR&sid=2447
What's even better is that using the "FlexStep" expert setting works great at properly tuning and displaying the irregular frequency steps of 12.5kHz in the 154.6500 to 156.2400 range. This was an annoyance with the PRO-96 since it would tune to the nearest fixed step instead.
It's been running side by side with the Pro-96 and BCD396T and doing great so far.
I'll post more by tomorrow to see if it keeps working fine since there's reports that some radios have gradually stop decoding P25 in the long run.....
rvawatch said:good to hear. jw, have you been running it under stat, roam, or none?
mancow said:It could be a parts issue or even a manufacturer problem....anything. I bet the design was nailed down pretty well. Once it goes into production it's kind of out of their hands but at this point anything is a guess.
One way or the other it will be nice to get it up and running. When it was working it sounded great.
BTW, it makes a great Satcom receiver. There is a strong signal right now on 253.850 and it sounds great on the GRE.
