mancow said:Real quick, can somoene tell me how to access flexstep? I can't seem to find the menu item.
It's in the expert global menu.
RoninJoliet said:Found another small problem on my GRE500 that i think was mentioned by the actual first users....On my Will County ILL Edacs STD (Wide) 6 channel trunk system the 500 misses the actual start of the transmission vs the PRO96...The PRO96 on Edacs opens the squelch a fraction before the 500 missing the first word on the 500...In quick conversations back and forth the 500 misses the quick call back....The 500 squelch is set on the "edge" as the PRO96 is....I have found many excellent features on the 500 and as mentioned im sure GRE will be very intent on solving the situations as my intent is to replace some old equipment with the new PSR600 base .....
mancow said:BTW, after my "hardware issue" the radio performs better than any other so far. The digital audio quality on the Kasas P-25 system is incredible.
It definitely has a good receiver too.
bonus1331 said:Added a wildcard last night to the local TRS.
Not sure what format the ID's are displaying when transmitting.
Can these be formatted into Uniden type ID's? i.e. 7XXXXX
jpryor said:It seems like the Private Call IDs might be in Hex format and not Decimal from what I was seeing briefly on one Motorola system.
Thank you......rdale.pinhead said:Hello guy's can sume one tell were to set my radio when using with a computer on the cd that comes with all i can find is how to clone radio to radio. thank you.
kikito said:-- One is the "FlexStep" option I'm using. It seems that some voice transmissions and some control channels that fall outside the "native" fixed frequency step when using this option, don't quite receive reliably. For example: one control channel's true frequency is 156.1375. With FlexStep Off, that rounds to 156.135. When I go to analyze that CC, it always shows good reception/decoding and you can hear the CC data audio. With FlexStep On, the frequency shows the correct step of 156.1375. However, when I go to analyze, it's hit or miss if I get a reliable decode rate and most of the time I get no data audio coming through the speaker. When I go to tune and punch in 156.1375, it's also hit or miss if it shows reliable data BUT when I step the frequency down two steps to the "native" 156.135 of the radio, it's starts showing good decode rates and audio again. SuperTrack On or Off doesn't seem to make a difference in this.
It doesn't really have "channels". It has "objects": conventional frequencies, talkgroups, trunking systems, searches, etc.scannerman5555 said:how many ch.'s this scanner has ?
DaveIN said:No, the output is not baseband (discriminator) audio only.
