Whereas the ideal place for a preamp is at the antenna, the GRE SuperAmp is not designed to be used outdoors, so that is pretty silly advice.
The answer is, as so many people have pointed out over the months in the fourms here, a pre-amplifer amplifes everything, noise, signals, everything. Using a pre-amp on a scanner invariably does two things:
1. On marginal signals, it increases the signal & noise at the antenna input to the scanner, with luck this will help you understand those signals better.
2. On clear signals, it increases the signal to the point that the front end of the scanner is overloaded and can no longer differentiate the signal from the total amout of RF being fed it.
Those two reasons are why the pre-amp has an adjustment on it. But in general, a pre-amp for a scanner is a bad idea. Most scanners are already peaked so much that putting an outside antenna on them overloads the front end, imagine what an amplifed signal does to them.
