Greene
cajunjerry
Springhill,La.
I see in the DB Greene County is not on MSWIN. Does anyone know if those low band frequencies still valid?thanks jerry
INDY72
Indianapolis, IN
Still on VHF high band as far as I know. No lea in Ms uses VHF low for primary any more and only a couple still have capabilities
Sent from my LG-K330 using Tapatalk
bama9999
Gulf Coast
Since they're not using VHF low anymore, can the database not be set so that they don't get scanned when you use the full database on the radios like the Uniden 436/536's? Seems that it would help speed up scan times by not having to scan through a bunch of unused frequencies when using the full database.
INDY72
Indianapolis, IN
I have tomorrow off and will do admin work on a lot.
bama9999
Gulf Coast
Thanks Milf. That'll be great. As you know, there's a lot of unused conventional freqs left in MS since MSWIN went into full effect!
