Greenwich Police - Missing Frequency
ASTRO_Man
Listening to GPD tonight on my scanner and I am hearing a conversation between a car and a mecic. I can only hear the one side of the conversation, the car. There must be a missing frequency in the TGRP. I tried to do a 800 MHz search on my PRO-106 but I could not find anything. Any clue?
cg
Connecticut
I don't know the GRE scanners like I know the Unidens but it sounds like you don't have it setup as a rebanded system. Entering all the channels is usually not necessary as the control channel will tune the radio to the correct frequency based on the channel number. The channel numbers match up to the correct frequencies based on the band plan that has been entered for the system. Check your programming and ensure it is set for a rebanded band plan.
chris
ASTRO_Man
It is, there is just a missing frequency. When I get back in, I will tell you what I have programed in my ARC500 Pro file.
ASTRO_Man
Here's what I got programed:
Highpockets
Toms River, New Jersey
You should be able to click Load Rebanded Table and it should fill in the tables, then after saving your file you can upload it to your scanner. I don't use that software, but, it looks like that is what it should do using that function.
Highpockets
Maybe with that software the blank space is a 0, so I could be wrong here, if so, I hope someone corrects me, and I didn't cause you any problems.
ASTRO_Man
This is "Load Rebanded Table" did: Does this look right? It just added zeros, would that make a difference?
Highpockets
I don't know, that's why I asked you to check the bandplan, the software I use puts the numbers in. Like I said maybe that software see the blank spaces as 0's.
cg
Connecticut
There are problems with that band plan. There should be no frequencies that are 848 and there are too many blanks (or zeros)
go to this thread:
Rebanding bandplan thread
and use either of the first two that are posted.
If the software generated that bandplan, I would be careful about any other system you created with it. Perhaps check for newer version of it.
chris
cg
Connecticut
What part of my reply in your old thread did you not understand? That would help in getting your system working correctly. You need to know how to edit a bandplan either in the software or in the radio itself.
Perhaps you can delete the existing bandplan and use the software to create a new one.
You shouldn't open up a different thread if you have a followup that is so close to the original posted question.
chris
ASTRO_Man
PRO-106. cg, your link was helpful. But the info in the bandplans didn't work.
JServidio
Here is what works for me to receive Greenwich:
Lo Hi Offset Base Frequency Step
440 559 440 851.025000 25.000
0 719 0 851.012500 25.000
Hope this helps,
Jerry
ASTRO_Man
Jerry,
You never miss one transmission? Not one? Does it matter if I have the information provided and more information?
ASTRO_Man
I mean if you see my table, the first 2 rows are what you said worked for you. If I have any more lines would that make a difference in my listening if I just the first 2?
tommyscan
seaford new york
I think jerry is working with a uniden as they require 2 entries.the radio shacks require
uire all 6 as stated in the wiiki. check your expert settings and dis-enable the priority feature,if you have it on?last night I monitored greenwich and had no problem. when I had my 106 the tables I e-mailed you worked?! Try deleting and re-entering the info from scratch or re-try the software and check all the settings before you download it into your receiver.if that fails, if you live close to newbritian ,ct-visit lentini communications excellent radio store.
ASTRO_Man
Greenwich System Rebanding - Driving Me Nuts!
Guys,
I have not found a successful rebanding table for my RS PRO-106. I have tried every table in the book:
http://forums.radioreference.com/ut...5682-custom-band-plan-s-rebanded-systems.html
http://forums.radioreference.com/ra...6-2096-rebanded-motorola-trunked-systems.html
NONE OF THESE ARE WORKING! I am missing some transmissions on each table.
There must be a solution! I don't know what to do anymore. It is driving me nuts. Can anybody help? How can I make my own rebanding table?
Here is the system I'm playing with:
Greenwich (Motorola Type-II) Trunking System, Greenwich, Connecticut - Scanner Frequencies
Maybe one of you guys are nice enough to make a raw table for me. Thanks for all the help, I just want to scan once and for all!
