Griffin spalding county
RomeRon
Rome Ga.
Steve, I don't believe that this system is actually up and running. The SYSID, and NAC don't show at all in the database. I wonder if he's tried the conventional frequencies?
Larry
I think you may be right, clicking on the FCC listings in the Spalding county database, comes back with nothing from them.
JCHEEVES
GRIFFIN, GA
Ok, I will try all of this and get back with you. I'm glad it hopefully not just me, I had become very frustrated with all of it. Thanks for all of the help.
JCHEEVES
GRIFFIN, GA
ok so I'm getting that sound on 853.5875, 852.9625, 853.9875 Does that mean these are the control channels? Should I redo my entries with these as control numbers?
RomeRon
Rome Ga.
I did not see the 853.9875 in the RR database, you could take those freqs and set them as a wildcard and see what you get, I don't know how to set it up as a wild card in any of the software (s) maybe some body else does.
Highpockets
Toms River, New Jersey
Hit the tune button, enter those freq's one at a time:
To the left of the freq you should have some info, what does it say?
You should see % of the signal and a SID#, what is the SID#?
JCHEEVES
GRIFFIN, GA
Ok so 853.5875 (3-4) bars signal strength, 852.9625 (2-3) bars, but no sid# on either??? Nothing but the feq number no other info on screen. I found the fcc numbers too and entered them all first, but im getting more with only the ones listed in rr i have one listed as wildcard and am picking up some on that too.
RomeRon
Rome Ga.
Have you done a cpu updated from the RS website? RadioShack® PRO-197 39,000-Channel Digital Desktop Scanner - RadioShack.com scroll down and click on Product Support and click on. Have scanner plugged in and turned on;
PRO-106 (#2000106) and PRO-197 (#2000197) Digital Scanners (CPU Firmware Upgrade 1.9 and PRO-106 (#2000106) and PRO-197 (#2000197) Digital Scanners (DSP Firmware Upgrade 1.4)
When you click on PRO-106 (#2000106) and PRO-197 (#2000197) Digital Scanners (CPU Firmware Upgrade 1.9 and choose RUN this box should come up, SEE PICTURE
JCHEEVES
GRIFFIN, GA
Me either spalding county seems to be the hardest. Im going to try to enter a neighboring county henry they are trucked but on a different system just to see how that goes...thanks for all of your help...i don't feel so stupid now..
nunyax
Walton County, GA
The RR database for Spalding's system isn't completely correct. Here's what's listed and missing:
851.0125 – conventional (8CALL90) WPKI744 (if rebanded)
851.1000 – not found for Spalding (used by Floyd and Forsyth counties)
851.2250 P25 trunking WQNP495
851.3250 – P25 trunking WQNP495
851.5125 – conventional (8TAC91) WPKI744 (if rebanded)
851.6000 – P25 trunking WQNP495
852.2000 – P25 trunking WQNP495
852.3500 – P25 trunking WQNP495
852.7250 – OpenSky WQNP497
852.8125 – P25 trunking WQNP495
852.9625 – OpenSky WQNP497
853.5875 – OpenSky WQNP497
853.6375 – P25 trunking WQNP495
Missing:
852.1000 – P25 trunking WQNP495
Try entering only the 8 frequencies for WQNP495 and see if the missing 852.1000 frequency helps.
The 3 channel OpenSky system is for data only and the other 2 frequencies are for mutual aid/interop.
Highpockets
851.2250 – P25 trunking WQNP495
Missing:
Thanks, maybe this will help JCHEEVES. I'm sure he'll read this and try it. :)
SCP814
Spalding County, GA
Spalding County APCO 25
Can anybody get Splading County to trunk on digital scanner? All I get is the talkgroup stopping and no audio. I'm using Pro2096.
