Hey all,
I am installing a new cb radio, and I have the antenna mount grounded. I have switched the installation multiple ways, but the antenna itself is receiving a ground.
I think it may be the bolt that connects the fire ring that's passing the ground to the stud mount, and that's passing to the spring and the antenna.
I'm at a loss with so many different mounting options, but not being able to stop the antenna from grounding.
The negative on the battery is connected to the inside metal panel near the engine. I ran a daisy chained cable to another petal part that connects to the frame, and I ran that to the stud to connect to the stud mount. I've repositioned the ground in different places, but either it passes the ground through to the antenna, or it doesn't get a ground at all.
I've watched countless videos of how to make sure the antenna is grounded, and to make sure there is no continuity to the antenna, but I have not found any help for when the antenna itself is grounded.
I bought an SWR meter, and it's off the wall with a 10+ reading. I basically set the SWR and flip it from PWR to REF, and it pushes the needle passed the 10 pretty hard. There's clearly a problem, and I am not sure how to solve this. I don't keep the radio on because I'm afraid it will burn out with a short.
Any help or tips on what to look for or what to do, is greatly appreciated.
