BCasto
I am a scanner enthusiast near Raleigh NC. Most of my listening is from digital trunked systems in the 700Mhs and 800Mhz range. I mainly use antennas on the back of the scanner and they normally do OK. However there are some sites farther away I want to receive.
I have been experimenting with different antennas and the best luck so far is from a TRAM 1089 BNC antenna https://www.amazon.com/1089-BNC-Min...&qid=1523467433&sr=8-1&keywords=tram+1089+bnc
I get the best reception when the antenna is sitting on a metal ground plane. I have read the size of the ground plane should be sized to 1/4 wave. Unless my math is bad, I calculated the ground plane should be between 3.5 in and 4.0 in for 700-800 Mhz.
My question to you antenna experts is this - if the ground plane is much larger than 4.0 inches, will reception be adversely impacted? Also, should the ground plan be round (not square)? I have a 24 inch square piece of metal and want some advice before I start cutting it.
Thanks much.
Thanks much.
