Grounding
Howdy
As noted in the prior post and a couple of excellent references (Motorola Tower) are well stated. While the NEC is an excellent house wiring reference, but (in my one-sided view) is-not in the RF world and I have historically not grounded my RF grid to the home electrical entry points nor grounding water pipes.
This might sound counter to reason, but using a multi-ground-grid 'isolation' seems to lower the noise levels on HF and get's me more indendent of other man-made noise generators. Ihave the space so that was a main factor....
Agree this is difficult for some station set up's as space and other factors prevent grids,etc....
The main point is tie the grounds together and get the Ohms lowest possible between any gounding points and do use a Poly or like (Alfa Delta also makes great units) arrestors as you might be more likely to get static damage than lighting in some parts of the country....
Be safe!
Thx
Bill
Howdy
Be safe!
Thx
Bill
