JamesWest
- Joined
- Jan 28, 2021
- Messages
- 147
- Reaction score
- 84
I bought my HackRF in 2014. It worked great and then I stopped using it a few years ago and now my same PC running SDR# can't see it. Device manager does not see it. The green USB LED is not lit. I have tried four different cables, one which was brand new. I am thinking the USB connector is shot. What happens is the source HackRF window in SDR# has no controls. There is no message saying SDR not found. The run SDR button works and some noise shows up on the waterfall. There is no signal as if input levels are at zero. Weird. I ran the original Zadig and it does not see the HackRF. Not sure if I am up for brain surgery to replace the USB connector. Connector visual inspection shows the pins to be ok but it is so small hard to be sure. I thought I would run this past the experts here in case there is some thing I have missed. Thanks.
